Page 16 of 70 FirstFirst ... 614151617182666 ... LastLast
Results 151 to 160 of 698
Thread: Dylan8's Vento
  1. #151
    Thanks for the input guys. Budget says no atm, so if it has to come out again in 50,000km or so that'll just have to happen. at this stage I just need to get everything in the one car so i can get the golf out of my parents carport before they kill me.
    Stage 1 of parts ordered:
    Engine Block Gasket Set
    Cylinder Head Gasket Set
    Ultimate VR6 Timing Chain Kit
    Throw Out Bearing
    Clutch Release Lever
    Fuel Filter
    Spark Plug x 6
    Pressure Plate Bolt x 6
    Screw x 10
    Thanks to Jrad for putting up with my million parts questions!
    Hopefully do a compression test will come out with ok results and i can get the vento moving soon.
    Stage two will be on to suspension bushes, wheel bearings, engine mounts, mk4 shifter, and sort why the engine is running a little too warm and a general tidy up to get it roadworthy and rego'd. Hopefully a healthy tax return will make this sooner then later.
    Project V VR 666 steps it up a gear
    Only 12months after the vento got dropped off at home
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #152
    Q
    Mine landed November 2009 buddy, don't worry you're killing it! Keep it up can't wait to see it, so glad it's black and you're not a noob with stance so it'll look/sound amazing.
  3. #153
    Quote Originally Posted by Mk3 AAA View Post
    Cheers man.
    Still think you should be finishing your beast
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #154
    Aug 2006
    Melbourne VIC
    Good form!
  5. #155
    Sep 2010
    Southern Highlands NSW
    Nice looking forward to it
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
  6. #156
    Cheers.
    Has anyone pulled their original front quarter off before?
    I unbolted everything but it still seemed to be stuck, a quick google search and interwebs check up shows its 'glued' down, i tried to separate the two carefully, but im in fear of bending the panel where it bolts down at the top.
    Any suggestions? or just go nuts
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  7. #157
    Point Cook, Vic
    heat gun and some form of putty blade/spatula type thingo to cut through the sealer worked for me. They are stuck down pretty hard though
    FOLLOW US ON FACEBOOK
  8. #158
    Quote Originally Posted by Tim View Post
    yeah it didnt feel nice... should i be applying something there again when replacing the guard? even if its silcon or something...? guessing its there just to stop vibration/movement?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #159
    Dec 2008
    Sydney/Canberra
    Had the same problem with my wreck yesterday.
    One guard practically fell off, while the othe required a little more persuasion.
    Good work on the pair of 3s, plus the Bora.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
  10. #160
    Cheers mate, ill be much happier when the Vento VR is running and registered though :p
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
