Page 14 of 70 FirstFirst ... 412131415162464 ... LastLast
Results 131 to 140 of 698
Thread: Dylan8's Vento
  1. #131
    Sep 2010
    Southern Highlands NSW
    not to worry Dylan changing gears on a VR is like rowing a boat, you can adjust the linkage for a better more direct feel but then that can only take things so far.
    clutch forks even new from the stealer ship are less then $50 the last time i checked.
    02j shifter tower conversion is the way to go if you want the VR to shift like a mk4
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
  2. #132
    Quote Originally Posted by Cookie28 View Post
    I've only driven a VR once but compared to my bora the shift was not as nice so i believe that its pretty normal for a VR to feel like that, and i also LOVE the gearshift in my bora and i haven't found a car yet that has a nicer shift (not that I've driven THAT many cars)
    yeah thats what im thinking... im sure there are better options out there again, but i know i like the mk4s so might go that way.
    Quote Originally Posted by mrVR6exy View Post
    oh nice. the strengthened ones are $90 before postage. so probably better off just buying a stock one and beefing it up
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #133
    Jun 2007
    Eastern Suburbs Melbourne
    *apparently* there is also a greater range of short shift kits avaliable for the mk 4 setup, as opposed to the mk 3 setup.
    i like volkswagens
  4. #134
    its been a while...
    but plans are to head back to Bairnsdale these coming school holidays, and get the car to a level i can drive it to Melbourne (at a minimum) as parents are starting to get annoyed about the broken looking golf in the carport. and its a bit hard for me to work on it 3hrs away...
    While there was lots of other parts I wanted (suspension refresh, hose kits, cv boots/CVs, engine mounts, mk4 shifter etc) but I just cant afford them right now.
    So here is what I have on the order list. Any other 'must haves' people think I should get while pulling the engine out?
    Thinking either ECS or GAP for my order. GAP kits seem to have less parts then the ECS ones, so not sure if this is a worry or not...
    Will hopefully be getting Josh to strengthen the clutch release lever by welding a plate to the top to suit the HD clutch the VR is already running (its already snapped two im lead to believe)
    Engine Block Gasket Set
    Brand: ES#: 2726 Mfg#: 021198011A
    Cylinder Head Gasket Set
    Complete gasket set for your 12v VR6
    Brand: ES#: 2262 Mfg#: 021198012B
    Ultimate VR6 Timing Chain Kit
    Complete VR6 chain kit including everything you'll need to do a chain…
    Brand: ES#: 8982 Mfg#: 021198501
    Throw-out Bearing
    A must replacement when you do clutch work
    Brand: ES#: 2167950 Mfg#: 02A141165G~LUK
    Pressure Plate Bolts - Priced Each x 6
    Bolt that secures pressure plate to flywheel, 6-required
    Brand: ES#: 263656 Mfg#: N10101001~OE
    Clutch Release Lever
    Be sure to change this when doing clutch work
    Brand: ES#: 272284 Mfg#: 02J141719C
    Flywheel Bolt - Priced Each x 10
    Used to hold the flywheel to the crank (12v VR6 only)
    Brand: ES#: 2636 Mfg#: N90539801
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  5. #135
    Sep 2009
    A new waterpump and crackpipe etc maybe? Easy to swap while the engines out, a bit of a pain while it's in I think.
  6. #136
    Aug 2006
    Melbourne VIC
    Are you planning to reco the head once its back in Melbourne?
  7. #137
    oh these are what the car already had replaced by previous owner
    Engine has new new thermostat housing with metal crackpipe and new water pump about 10k ago
    2.5kg Fidanza Flywheel with replacable steel friction plate
    Sachs HD clutch (~40k old)
    New Drivers Side Driveshaft (full assembly) ~15k old
    New Fuel Pump ~10k ago
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #138
    Quote Originally Posted by Water Boy View Post
    yep. hopefully your sorting a contact for me still?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #139
    Sep 2009
    Not sure what headgasket that kit comes with but if you get a mk4 metal headgasket instead of the standard mk3 one it bumps up compression a little bit and is one of the easiest ways to make a little more power out of the motor if you have the head off anyway. Something to keep in mind. Have you read through this thread before VWVortex.com - How to build a relatively inexpensive, reliable, powerful Vr6.. ? Heaps of good info in there
  10. #140
    Aug 2006
    Melbourne VIC
    Yeah no probs. You get yourself a VRS kit (head gasket, valve stem guides etc) we pull head off and take to bakers to reco and mild p&p.
