Page 13 of 70 FirstFirst ... 311121314152363 ... LastLast
Results 121 to 130 of 698
Thread: Dylan8's Vento
  1. #121
    not much happening with the VR/Vento. Have been focusing on the Bora/BBS RS again...
    guessing the leaking the VR is from the sunroof after finding the original install/warranty information on it, but now the jeep is gone its undercover anyways.
    havnt had a look as i cant get to the back on the vento atm, but do people think the VR tow setup could be moved across to the Vento?
    Did buy myself a BBS stock wheel for the VR for $5, so now i have a set of 5 instead of that scary looking space saver.
    Got some side skirts off Stu.
    Also got a set of Thule roof racks so now have somewhere to store parts rather then fill up the shed floor.
    Back to splitting RS and removing 165/40s and 185/35s off 8s and 9s
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #122
    Spend a hour or two with the Vento this arvo between sleep and work.
    VR seats saw some cleaner and conditioner.
    going to give them a second go and see if it softens them up even more.
    Pulled the bumpers on the VR and pulled the frame for the toe ball off and hopefully it fits to the vento.
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  3. #123
    can any one confirm what steering rack I should have in my vento?
    quick search shows the ZF rack has a square waffle finish like this:
    and the TRW is smooth. mine appears to be smooth (TRW), just want to double check its the original part etc, is there anywhere to look up a list of what years/models came with what?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #124
    Eastern suburbs of Melb
    Alllllll the same
    Sent from my XT910 using Tapatalk
  5. #125
    Quote Originally Posted by thestu View Post
    Alllllll the same
    what you mean? all aussie are TRW? because im buying bits from ECS and makes a difference to what I buy in regards to tie rods and things...
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #126
    Sep 2009
    This has got me pretty confused before too. I think it should be a TRW but I cant be 100% sure. If your's isnt waffely like in that picture then yes Im under the impression its a TRW
  7. #127
    Do you need one? I have 3
  8. #128
    nar im good cheers! buying some refresher parts is all
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  9. #129
    did some more interneting/googling and less work on the car...
    I came across this. maybe the source of my dodgy feeling clutch, apparnelty a problem when upgraded clutches are installed, and Tim pointed out this car already had a problem with the fork not long after the clutch was originally installed.
    Refer the bend...
    if that is the case, plan is to either buy or make this (pending on the cost of a stock unit...):
    Will suss out if that is the problem when its all out, as Josh pointed out might be worth while strengthening it anyway!
    also not sure if a mk3 thing or just my car in particular but the gear box feels very sloppy compared to my mk4, mk4 just goes where you want it to go, VR really needs some directing into the right position.
    thats when I came across guys doing a mk4 0j2 shifter swap. These were the comments about it:
    By swapping the shifterbox, cables, and shift tower(in the transmission) from a mk4 5spd car, shifts will be much smoother and precise. Putting the Mk4 shifter box in only requires that a few holes be drilled in the floor, and some extended studs bolted into the box. This is a great shifter, and oem upgrade
    This is defiantly something that interests me, as I do enjoy the feel of the mk4 shift over a lot of other manual cars cars
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  10. #130
    Feb 2010
    Seaforth, NSW
    I've only driven a VR once but compared to my bora the shift was not as nice so i believe that its pretty normal for a VR to feel like that, and i also LOVE the gearshift in my bora and i haven't found a car yet that has a nicer shift (not that I've driven THAT many cars)
    2014 Golf GTI PP - Pure White
