Results 31 to 35 of 35
Thread: Dubster's Vento
  1. #31
    Munno Para West Adelaide
    Heres a better pic
  2. #32
    So not much has been happening lately. Went to get regassed and compressor wouldnt hold pressure, going to risk getting one from a wrecker. Read online its a common problem and was told today if the aircon doesnt get used for a while they do fail, anyone know which is true?
  3. #33
    Nov 2015
    If my memory serves me correctly, the refrigerant gas acts as a lubricant on the seals and the working parts of the compressor. If you do not use the aircon for an extended period, the seals can dry out and fail and you will lose your gas and the compressor will become unserviceable. I was always told to run an aircon unit once a week for 15 mins to give it a good lubrication (this applies to your home reverse cycle split system aircon too).
    1997 Golf CL, 2011 Caddy Life TDI, 2007 Golf TDI, 1996 Vento GL (red), 2008 Skoda Octavia TDI
    1996 Vento GL (white) - RIP
  4. #34
    Hey guys not much has been happening with the vento atm. Aircons fixed and been driving everyday fine, but now theres a problem! The mrs rings me up on the way to work saying the cars cutting out on her whilst driving. Alot of shuddering whilst driving especially at low revs and sounds like the time my icm died on my mk4 but not sure if this could be it. Previous owner did mention about the ignition switch needed to be replaced he was told by a mechanic does this sound about right? Need some advice as I need it running good soon.
  5. #35
    Vento will be going up for sale in the next couple of weeks. Mrs wanted something a bit more modern so got a polo tdi!
