If it feels as though your key is just not doing anything, your lock barrel could have broken... or, the air pump could have become unplugged and is therefore not activating that particular door. There are a few different things it could be.
Can you get the door to unlock when you use the key on the passenger side? If you can, then the air is pumping fine so I'd put my money on the lock barrel.
The best thing to do would be to take the handle out (one torx screw at the back of it on the inside of the door, then you slide the door handle forward, put the key in, turn the key 90 degrees left or right and pull the back of the door handle out) and have a quick look at the locking part to see if you can see any obvious damage. you put it in by reversing the above method
Hope that helps
