Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: Dreaded ABS Issues
    Jun 2013
    Melbourne, Australia
    Dreaded ABS Issues
    Hey Guys,
    So had my VR6 scanned and it came up with the following codes:
    00276 - ABS Outlet Valve, Rear Left
    00290 - ABS Wheel Speed Sensor, Rear Right
    00287 - ABS Wheel Speed Sensor, Rear Left
    Okay so basically after about a weeks worth of searching, I'm going crazy.
    Some people are saying that the 1st code is a failed ABS pump and if replaced, the other 2 codes will disappear.
    Some people say different, but I'm all fine with this.
    I'm happy to replace the ABS pump and both sensors if needed but my issue is this.
    Do I need a specific ABS pump or does it need to be coded to my car?. I've found 1 on eBay which I was going to buy but I'm having reservations now because of all this coding talk.
    I guess my question bottles down to this: Can I buy any ABS pump/control module from another VR6 and throw it into my car or does it have to be a specific one? And does it need to be coded?
    Mine is a 1995 OBD1 VR6.
    Cheers Guys!
    2012 - Tiguan - 155TSI - DSG - Black
    Feb 2014
    Northcote, Victoria
    Hey mate, I had the same issue on my OBDII 98' Model VR6 MkIII
    It ended up being the ABS control module, its pretty common for board connections to go dodgy after time requiring a decent solder repair job. Mine was fixed after RWC despite when I bought it and they had to fix it for free, so can't give you a price guide sorry mate.
    Previous VW; 6n3 Polo 16v, MkIII VR6
    Current; 9n3 Polo GTI
    Jun 2013
    Quote Originally Posted by Gillzy View Post
    Ahh nice! Okay well at least it might just require a repair to the module instead of a new pump and module.
    Any of the conversion guys out there wanna chime in?
    May 2014
    Newcastle, Australia
    Mine has every code related to abs possible. Removed the abs module and re soldered all the large soldered joints on the board. Put it back in and reset the codes and all has been perfect since.
    Jun 2013
    Quote Originally Posted by cliftronix View Post
    Was it obvious which areas needed to be re-soldered?
    I might give that a shot and see what happens. Should the ABS warning light go off after reinstalling the module? And then I follow up by wiping the codes?
    Thanks
    May 2014
    I soldered all the large pins through the board. And most of the input pins. Look for dry joints and you should be fine. Yeah just remove the module, it Is held on the bottom of the abs pump by 4 8mm head bolts and remove downwards. Replace and clear the abs codes and hopefully it should be good.
    Jun 2013
    Ahh awesome! Yea I'll definitely give that a go. Even if it doesn't work it isn't costing me anything.
    I'll also use a multi meter against the rear ABS sensors and make sure they're reading the correct voltage and replace if required.
    If neither of those work, I'll just replace the module!
    Jun 2013
    Okay... So it turns out my VR6 is one of the ones where the ABS/EDS controller is separate from the ABS pump and is under the rear seat, making things 100 times easier.
    I removed it and took it apart and it looks perfect, no loose parts, circuit board looks great.
    Is there any checks I can do to check this sole part for operation?
    Seriously hoping it's not my actual pump that's gone, think it's too big of a job to tackle myself!
    Have you inspected the solder joints? I get a few vags a month where the solder joints are dry.
    adelaide
    Please keep us posted... Mine has similar codes, i just havent bothered to fix yet as i didnt know where to start.
    1996 VR6 Golf
