When I leave the key in and turn it so that everything turns on, but not the car. After a while the central locking pump will randomly go off, but the doors do not lock or unlock.
It will do something maybe three times in a row, then wait a while with nothing, then do it again.
Is that normal?
Can anyone replicate it?
Not really a problem, just wondering if it might be my keyless entry module picking up noise and being set off.
Past - '95 VW Golf MK3 VR6
Might be your ignition switch, does the key require some jiggling to work ?
Those clicks behind the dash are relays for the vacuum pump under the front quarter panel, but if the pressure is dropping (via say a vacuum leak) might be causing it. If you open the door does it continue (key still in)?
