Results 1 to 6 of 6
Thread: DIY Timing Chains
    Jan 2007
    QLD, Gold Coast
    DIY Timing Chains
    Hey fellas,
    Got the chain kit from GAP, just wanted to know if you need to replace gaskets at all?
    Camden, Sydney
    You should but the correct sealant from vw. $60 a tube, but it will never leak.
    Sealastic will leak. definately
    Sep 2006
    Australia?
    Yes it will...
    Jan 2007
    QLD, Gold Coast
    Thanks for the info,
    How many tubes would one use?
    Oct 2006
    You might as well get the gaskets from gap as well for piece of mind and torque the inlet and rocker up to specs.
    Jan 2007
    QLD, Gold Coast
    Well job complete... Guides and chains changed and HD clutch installed. Did the job with the engine in and all went well. I had a broken upper guide, the plastic had snapped around the bolt. So good weekend and learn't alot.
