I don't see why you cant do it, as long as the welding is decent.
You'll have to be careful of the rubber lip though as the metal hat has 3 or 4 small hole in it that the rubber is molded through if I remember correctly.
I know how you feel about the big gap, mine has similar issues even after replacing the top mounts. But one of my hats is shaped slightly different to the other so I get an uneven gap as well.
these are my hats
Although if yours is a later golf or a vr6 then I think your caps will have 4 ribs pressed into them which would make it a bit harder again.
