Before applying the JB-Weld, I washed the whole thing in hot, soapy water, and then dried it thoroughly. Next, I wiped down the area around where the boot glues on with acetone, to remove any traces of contamination:
Here's the high-temperature silicone I used - Loctite blue:
I mixed up a batch of JB-Weld and glued the boot back on over the terminal. Even without the epoxy, it was a snug fit, and with the epoxy on there it went together very well and seemed to make a good seal:
I did some research on JB-Weld, having been told it was the stuff to use, but I wasn't too sure of the availability here in Australia. I saw an aussie place selling it online, but for something like $27 with $8 postage. I then found it in, of all places, K-Mart, for $16.95. I checked out the
FAQ on their website as I was worried that with metal particles in the epoxy, it might conduct electricity, but
apparently it's an insulator:
I then applied gentle clamping pressure for a few hours while the epoxy hardened:
Here's a closeup of the busted coil. The part has simply failed, there's nothing putting any pressure on this part in the engine bay, the ignition leads aren't under any tension, there's nothing banging into it, it just simply broke off:
After the first batch of epoxy dried overnight, I then covered all the seams where the black shiny potting compound joined onto the plastic - all around the boots and all around the edge:
Here it is, from another angle:
Then, I covered the sides with a thin layer of epoxy as there were some hairline cracks already developing (I've really got no idea how old this coilpack is) and I didn't want them to get any worse. After this had cured for a few hours, I next covered the whole thing with a thin layer of silicone - reasoning that even if the epoxy cracks slightly, the silicone should be flexible enough to keep it sealed and hopefully help it last longer. I didn't want to put too thick a layer on, as I don't want to provide any additional thermal insulation - I don't want to keep heat in the coilpack, as it is bolted quite literally right onto the side of the engine
Here's a closeup with the silicone showing a pale blue colour, over the grey of the epoxy. I won't be winning any prizes for a neat, smooth finish, but as long as it works...
Here it goes - putting it all back on. I didn't take any photos of taking it off (which was pretty easy) however if you want directions, skip to the end and work backwards, it's an identical process, just in reverse:
Tighten up four hex-head bolts - 5mm from memory:
continued...
