Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: DIY: Fitting a MKIV gearknob on your MK3
    Jan 2007
    Having a complete lack of an install guide I've decided to make my own with proper pictures and instructions on how to fit a MKIV gear knob on your MK3. This took me about 30 minutes including buying the small hose clamp required.
    What you need for this:
    A new shifter with an integrated gaiter and an elastic base
    A small hose clamp for the base of the shifter shaft
    A hack-saw to cut through the shifter shaft
    Some masking/sticky tape to mark the distance of the cut to the shifter stalk
    A flat head screw driver to adjust the hose clamp
    A rag/cloth to cover and collect any excess metal
    So here is the first step: Observe how atrociously bad your gear knob is and decide to get a new one!
    (Thanks Marshall! aka. Sierra055)
    Secondly: Remove your old gearknob and/or gaiter by unscrewing the old knob and pulling off the gaiter from the shift gate trim:
    Thirdly: Measure 35mm from the top of the shifter rod and mark the distance with a piece of tape, then begin to cut it with a hack-saw:
    Fourthly: File the top of the shifter stalk until its flat and you have reached the 35mm marking. Remove the tape and sand vertically to make the surface and bit more abrasive and remove any sharp edges:
    Fifthly: Insert the hose clamp over the bottom of the shift knob as seen here:
    Sixthly: Push the gearknob over the shaft and position correctly, then begin tightening the hose clamp until its secure:
    Finally: Re-insert the shift gate trim and pull the base of the gaiter over the trim and it should hold well, and ENJOY
    Looks neat !
    Did you saw off because of length? Mine screwed in just fine.
    Jan 2007
    Quote Originally Posted by Soundofav6 View Post
    Looks neat !
    No actually, alot of the later models did not have a thread, hence why you would need to cut it and put the hose clamp on, I just gave it a drive now and the shorter legnth definately helps imo.
    Sep 2006
    Australia?
    Looks neat !
    Louis that would be because you have a short shifter it has a smaller shaft.
    Quote Originally Posted by Golf Houso View Post
    I did this to my VR a couple of years ago and had to cut aswell, well done its a cheap mod that looks the goods!
    Feb 2006
    Devonport, Tasmania
    hey mate that looks great
    i did the same thing with my setup (mk4 r23 shifter and boot)
    i had to do a bit of cutting of the centre console though
    2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
    1986 SAAB 900 Turbo 16 S
    Aug 2006
    Melbourne VIC
    Nice mod! Geez I wouldnt be too keen on cutting my shifter
    Dec 2007
    Ermington, Sydney
    I'd want to upgrade the handbrake boot with it...who knows whether or not that's possible?
    Quote Originally Posted by tassie_euro_mk1 View Post
    Thats tight !
    Like the finishing touch on it..
    Apr 2009
    North Ryde, Sydney, NSW
    Will any hose clamp do?
    Because it is not threaded.. does the gear knob have much rotational play when shifting gears?
    How much is a mk4 knob/boot set on average?
    2012 MY12 Octavia RS Wagon
    DSG, Black, Sunroof, Leather, HIDs, Michelin PS3.
    Jun 2009
    Auckland, New Zealand
    Quote Originally Posted by Mrk_Mickey View Post
    You could try and source one from a Mk3.5 Cabby
    I want to try and find one of those wheels as well
    2016 Golf Alltrack
    Previous:
    Mk3 1.8t
