Results 1 to 3 of 3
Thread: Distributor 2.9 swap to 2.8 coil pack.
    Jun 2011
    Hi guys, I'm taking a shot on this and seeing if you guys have any info.
    From what I've seen on the tex is that.
    I'll need:
    Upper timing cover
    Cam sensor trigger (mounted to rear cam on top of cam gear)
    Cam sensor
    Coilpack and bolts.
    ECU for OBDI coilpack
    Engine harness
    Things I'm not 100% on:
    ECU harness.
    MAF - early OBDI VR6's had the hot wire, then they went to thin film (still OBDI)
    Basically all those things. Now, what I'm wanting to do is put a distributor-ed 2.9 into my coilpacked 2.8. Now by having that list is it simply as straight forward as swapping it all over?
    Or could I put my 2.8 head onto the 2.9 block and avoid all of these problems?
    P.s mods move if they feel it will get better responses elsewhere.
    Thanks Hayden.
    Feb 2008
    mOOROOLBARK
    i believe the head will bolt up check vertex then you will know for sure
    Camden, Sydney
    Swooping the head is quite complex and costly on a vr6
