Results 1 to 10 of 14
Thread: Died while driving?
    Mar 2014
    Bundoora, Victoria
    Thumbs down Died while driving?
    Accelerating to about 5k rpms and then the rev count oddly fluctuated and then dropped to 0 and my battery and check oil light came on and power steering went. No response from throttle.
    Had to quickly turn into a side street (couldn't believe how much of a different not having power steering makes)
    and restarted. Let it run for a little.
    Everything was fine after that.
    What could have caused it to suddenly die like that? I've had it run rough before after that kind of scenario and usually letting it go into neutral for a second or two fixes it up and I can continue.
    It's never gone out like this before though.
    Past - '95 VW Golf MK3 VR6
    May 2014
    Newcastle, Australia
    Coilpack?
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by cliftronix View Post
    Coilpack?
    How can I check? (sorry if noob)
    May 2014
    Quote Originally Posted by stefcio007 View Post
    You can check your whole ignition system through this method
    VWVortex.com - How to test VR6 coilpack (from Bentley)
    but the easiest way is to just replace it with a working one and she if there is any change.
    I had the same thing happen to me a week into owning my vr but hasn't happened since then.
    Jun 2011
    Sydney NSW
    The first thing to check would be the battery. How old is it?
    Dec 2006
    Kilsyth, VIC
    Earthing? Sudden and total power loss screams electrical to me.
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by The_Hawk View Post
    I've had the stereo completely reset on me once or twice so that sounds likely and my battery level without engine running shows around 11V, normal?
    Jun 2011
    Sydney NSW
    No.
    Get it tested under load. You probably have some cells out.
    Jun 2011
    Does the car start?
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by wai View Post
    No.
    Shows about 14V with the car running.
    Does the car start?
    Yes, starts.
