Page 3 of 6 FirstFirst 12345 ... LastLast
Results 21 to 30 of 51
Thread: Damn Headlining
  1. #21
    Jan 2007
    where do you purchase this polar fleece goodness oh mighty one?
  2. #22
    Dec 2006
    Kilsyth, VIC
    I bought it at Lincraft, but spotlight should also have it as should any fabric shop, it's *very* common.
  3. #23
    Nov 2006
    Central Coast, NSW
    nice workmate! glad to see my tutorial helped!
    that glue worked well - i'm actually thinking of re-doing mine in a different colour and maybe with a stripe!
    the stuff I used was about the same thickness, but i got regular cotton fleece (which is smooth on one side and furry on the other). this gives me many ideas on lots of different fabrics.
    i think this should be a prerequisite after purchasing a golf! it really does make a huge difference.
  4. #24
    Seven Hills NSW
    Hi, does anyone out there know whether large hail damage to the roof of my vr6 would cause the headlining to sag?? I only noticed the sag just before christmas when I happened to be in the back seat (after the car was inspected by the insurance company). If anyone knows for sure that the hail damage would cause it then I can start the battle with the insurance company.
    Steve
    Steve's black vr6
  5. #25
    Dec 2006
    Kilsyth, VIC
    In my expert opinion, no way on earth would hail damge effect the head lining material. Luckily for you it's a relatively quick (and cheap) thing to fix yourself...
    I wonder what the pro's charge??
  6. #26
    Nov 2006
    Central Coast, NSW
    sorry to say mate but the headliner isn't attached to the roof in any way at all... it is a 10mm piece of foam all held up by the side trims and the roof handles...
  7. #27
    Oct 2006
    meh just say that the hail damaged the headliner which eventually led to it sagging.
  8. #28
    Camden, Sydney
    Nice work Hawk
    You can buy proper headlining fabric from a mob in Alexandria for $30 any colour you like and I use the cheapo contact adhesive that comes in a tin and you spread it on with a brush. Its $10 a can.
    Your looks good though mate, nice effort.
  9. #29
    Nov 2005
    Sydney NSW
    FYI:
    When looking for material you need something 118 cm wide or greater.
    Alot of good prints at Spolight are only 112cm wide and possible not wide enough. The widest cloth covering part is between the front seat grab handles. Material needs to go into the bumps and dont forget you should have some to wrap around the edges - but if your keen you do not need to as the trim does cover about 10-15mm of the headliner sides. 112cm wide material is cutting it pretty fine but might be do'able.
    You will need about 2m in length, more if you have to cover a sunroof.
    You can get the 3m High Strength 90 Spray Adheasive from TOTAL Fastener http://www.totalfasteners.com.au/ You can only get it from Industrial suppliers... so no Bunnings or Auto Parts stores.
    RRP $29 /can
    ADHESIVE AERO HIGH STRENGTH #90 471GM
    I'm doing my headliner right now and found to clean the bad foam off the headliner board it was quicker and easier to use a cordless drill and a small Finishing mixed Flap wheel (Sandpaper and Scotchbrite sandwich bought at K-Mart).
    \( O ) o\====(\X/)=TDI=/o ( O )/ 2011 Jetta Mk5 125TDI - Squidly
    ((o)(O))====(\X/)=TDI=((O)(o)) 1996 Golf Mk3 TDI - Squid
  10. #30
    Mar 2007
    sydney
    lookksssssss good man top stuff.
    mk4 the mods begin for round 2 hahahha
