Pull the circlip off the inner one, knock the tripod joint off, and slip the outer one off the inner end.
That is of course if it's the set I think it is.
I had a cracked CV boot so I bought a replacement. Got the axle out of the hub but I don't know how to get the boot over the end of the axle, any ideas?
'07 Transporter 1.9 TDI
'01 Beetle 2.0
So you need to remove the whole axle?
Yeah, and you need an 8mm multispline bit to undo the bolts.
'01 Beetle 2.0
yeah all good have a set of them. I'll give it a shot tomorrow.
