Go to Heasmans at St Peters for good wheel alignment, ask for Doug
Thanks
1DUB2C!
I got the cheap tyres it was great value![]()
I got my wheels alligned there as well
but they say they can't do the camber![]()
I went back with the workshop manual
and said you can do it look!! and then they pulled
the whole we don't have the tool.
do all mk3s have the tool on the car some
where??
that 'tool' be a 18mm (or near that)? spanner! just lazy. no special tool required. just take your wheel off and you can see the two bolts on the strut that if loosened, will give you the play for the camber
\'95 Golf VR6
where did you get the tyres from and what brand?![]()
Mate go to Vw and you can buy camber correction bolts that replace the original ones. They have a couple of thou shaved off them. No special tool pal
Alba European
Yeah mate you would need to have the geometry set after you fit the bolts, whoever is doing the adjustments are best to fit the bolts at the same time. You only need 1 per side mate thats normally enough
Alba European
