Results 1 to 8 of 8
Thread: Cruise Control
    Oct 2012
    Cruise Control
    Hi guys,
    I'm attempting to get my vr6 cruise control working. I've done all the diagnostics on it (pump works, vacuum is holding, all the switches on the stalk work and send power to the ecu plug) and have narrowed it down to the Cruise ECU. So being the tightass I am, I went to a wrecker and picked up 2 ECUs off some mk3 GLs for 20 bucks.
    Surely one of the two would work... Right? WEll apparently not. I've had both in the car and I'm not getting any response from it whatsoever. Not even a glimpse.
    So the question is, is it likely that both of the ones I've bought broken as well? Or is there something I'm missing like a relay or a fuse?
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Sunshine, Victoria
    The relay in these always and i mean ALWAYS cacks themselves in these. There is a tutorial somewhere on how to replace it and get the unit working again. I'll hunt around and see if i can find it for you. Its pretty simple as long as you can or know someone with basic soildering skills.
    That bitch fried my tyres!
    Sunshine, Victoria
    Oct 2012
    Thanks for that mate. So it's not worth trying another unit? Where would I get the relays they talk about?
    Sunshine, Victoria
    Super Cheap, Orderbahn, Jaycar. Common automotive relay probably cost you about $2-5. I suggest getting a body gromet for the hole you feed the wires thru and some heat shrink to keep it all nice and neat.
    Oct 2012
    Did the relay repair but it still won't work AM I missing something? Ive tested and I'm getting power to the 12pin plug but nothing happens when im driving and i turn it on a press set.Need ideas! Do I need to be in fifth gear and doing over a certain speed or something?
    Oct 2012
    Fixed! For those interested, I did both the relay and this : Definitive solution to repair cruise control module 5GA 004 397-16 - AudiWorld Forums Fix.
    Sunshine, Victoria
    Great. Now you can sleep on the freeway lol.
