Results 1 to 6 of 6
Thread: Cruise control
    Sep 2014
    Cruise control
    So my cruise control has never worked in my 97 vr6 and im just wondering if thats because the abs light is on?
    Mar 2016
    Hunter NSW
    I think that's a fair conclusion. I'm sure the cruise computer wouldn't operate if all systems weren't ok. It probably has a feed from the abs system. I'm about to start a cruise system retrofit so i'll post up any info that i discover.
    Peregian Beach
    Quite often if the cruise isn't working it will be caused by one of the micro switches, either on the brake pedal or clutch pedal. It could also be the switch on the stalk.
    Dec 2006
    Kilsyth, VIC
    Can you hear the relay clicking when you try to turn it on and activate/set it?
    It's run on vacuum with a reservoir in the front quarter panel that runs up to a valve near the firewall then into the cabin where it pulls on the accelerator. The reservoir can crack, the plastic lines deteriorate... lots of reasons. But the relay should still click if the system itself is working.
    As for the ABS light. Maybe, but my ABS never worked (although I think someone had removed the bulb since mine wasn't on ) and the cruise worked very nicely (although if you hit a big bump it would stop which I assume was the brake switch knocking).
    Jul 2005
    cruise control works from the signal in the ABS system for wheel rotation speed. If your ABS light is on then fair assumption this is stopping your cruise control from working.
    1974 1300 Beetle, 1997 Golf GL, 2003 New Beetle Cabrio, 2014 Audi A4 quattro
    Dec 2006
    Kilsyth, VIC
    There is a wheel speed sensor for each wheel and all of mine worked fine. Just the ABS pump/board/something? was dead. Maybe it's possible to have it part working for cruise control to work??
