Results 1 to 10 of 12
Thread: coolant issues
    Sutherland Shire, Sydney
    coolant issues
    so i finally got around to putting coolant in my car today. all was going well, i ran it with the heater on for around 25mins, no problems but as soon as the temp gauge got to the middle, coolant start to come out of the expansion tank.. is this normal? ive never changed coolant before. i was using the G12 ++, it went in transparent pink, but when i turned it off and let it cool down its now milky green?
    do i need to flush it? and if so is there a release valve on the radiator. i havent had a chance to jack it up and look yet.
    thanks
    95' golf VR6
    Dec 2006
    Kilsyth, VIC
    I don't know that green sounds right at all...
    As for coming out, it will burp itself as needed, how much are you talking about??
    arh ill have to have a closer look tomor about the green, not so much green but very pale milky.
    anyway it seems to be coming from the side of the tank, where the black side area saying G11 is, fair amount ill give it another run tomorrow and see if the same amount is coming outand let you know. may have been overfilled
    95' golf VR6
    Adelaide hills, SA
    Quote Originally Posted by G_1991 View Post
    thanks
    It looks like you had a green coolant there before. I personally would flush it, at least couple times to be sure.
    Sent from my HTC Desire using Tapatalk
    Yeh i had a feeling thr guy before me didnt use the good stuff, also i found out the real reason blutak was invented... For vr6 owners to get that bloody crack pipe screw back in.
    Sep 2009
    iirc g12++ does not like to be mixed with other coolants at all and so it might be a good idea to flush it all properly and fill up again (although there goes like $60 of new coolant )
    Dec 2006
    Kilsyth, VIC
    I have heard green + pink = brown sludge...
    Yeh someone must of done that cause it was a sludge colour. Alsomy heaters disconnected is putting ac on a fair alternative?
    Sep 2010
    Southern Highlands NSW
    a fair alternative to what ?
    Polo GTI
    T-Roc R
    Tiguan R
    Tiguan 162 Allspace Wolfsburg
    My bad brain snap moment to much grog still in my system when i posted that.
