If its the nut below the bottom spring seat and its all the way down the bottom of the thread that is the lowest you can run them, should be scraping its ass on the ground at that level I imagine?
hey all got them on ok and iv got the adjust nut wound all the way down does that mean thats the lowest or the highest the suspension will go cause i wana go a bit higher and i assume with the nut all the way down that means thats the highest it will raise the car???????? because at the moment the car is tooo low
Forever blowing bubbles.
can't wait for a review and some pics!!!
pics or ban!!! lol
Rude awakening after oem. Handling makes up for the ride though
ooooooooohhhhhhhhhhhhhhhhhhh yeeaaaahhhhhhh f**k yeah thats right soooooooooo much better, excitement is overwhelming if anyone is thinkin bout gettin these it is well worth the money, they all seemed to bolt on allright except the front ones have an allen key insert on the top to hold the strut so you can tighten them up 7mm and the kit didnt include a 7mm allen key, 7mm is an odd size so i had to grind down an 8mm allen key to get it in, extremely annoying
anyways that was the only down side to this kit ride quality has improved ten fold
no more body roll
also traction has improved i assume that because of the stiffer suspension there is less weight transfer hence more weight on the front wheels
and i cant put my 16x8s on yet cause i have to get my guards rolled and some thinner tyres so runnin the stocks for now
il post some pics wen i get my 16s on theres not much to look at yet not very exciting but yeah very happy
for those who want to get these on the fronts i measured 45 mm from the bottom of the lock nut to the bottom of the thread
the rears are about 65mm
PICS petey PICS!
Glad to hear they all worked out though. It would be interesting to compare these to another brand of coil overs. see if there is any real noticeable difference?
me not knowing how other brands feel i have no idea but they seemed fairly comfortable to drive with a lot firmer but the ride wasnt too harsh just rite i must say
good to hear, looked sweet as sitting on its arse when i left.
yeah man thx toobad i cant roll on me 16s yet
it drives as good as it looks
