Results 1 to 10 of 14
Thread: Which coilover to buy?
    Jan 2013
    Redfern, NSW
    Hey,
    So my suspension is ruined on my 98 VR6 and I'm looking to do a cheapish replacement. I had looked at Bilstein suspension but it's way out of my price range. Was looking at $2,400 for everything including installation, but considering that's almost half the value of my car it probably isn't the smartest idea :-0
    I've read a bit and have found the following kits. Does anyone run either of these that can give some feedback or advice? They seem to cheap to be good?
    ECS Tuning Streetline Coilover Kit (Volkswagen Golf III VR6 12v > Suspension > ES#250776 Streetline Coilover Kit - Fixed Damping - SMVW8001KT)
    CX Racing Coilover Kit (92 98 VW Golf MK3 Coilover Suspension Racing Drift | eBay)
    Cheers,
    Dan
    Aug 2006
    Melbourne VIC
    CX racing, Weitc, KW, H&R. All good brands. ake sure you replace your upper strut mount and rubber while you are at it.
    Mar 2011
    Inner West, NSW
    Quote Originally Posted by water boy View Post
    make sure you replace your upper strut mount and rubber while you are at it.
    ^^^^definitely this
    May 2012
    Perth, Western Australia
    Well I can't speak of the CX ratings, but I've got a set of Streetlines in my 2.0lt now and I've had no troubles, go decently low as well. I've got them would all the way down at the front but I need to roll my fenders now because they rub. And the rears have maybe an inch and a half to two inches left of threads, but they are rubbing too. The ride isnt TOO bad, havent had any complaints but you will defiantly feel the bouncy-ness. But by all means they are a great decent set of coils for the price.
    Photo for reference. They where maybe 5-10mm higher at the front that day due to 'spirited' driving.
    1990 Mk2 GTI 20vt - @mk2.20vt
    Jun 2012
    SE Melbourne
    I think we need a sticky for this topic already...
    +1 for CXRacing.
    SILVER '98 MKIII GOLF GL // BORBET TYPE A's
    YELLOW '76 B1 PASSAT LS WAGON
    WHITE '07 MKV JETTA 2.0 TFSI
    FLICKR
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by DBT_98vr6 View Post
    Is it just the damping that is gone? If so, just get a set of Koni or Bilstein dampers as you will get better suspension control for your dollar - no need to go for coilovers unless you want to lower it.
    Quote Originally Posted by veedubMK3 View Post
    You want to avoid this result which is typical of cheap dampers (in this case, in the coilovers)
    Resident grumpy old fart
    What do you want from it?
    Just a replacement, or upgrade in performance too, or lowering?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Aug 2006
    Melbourne VIC
    Also all remember our cars are coming up to nearly 20 years old so all the bushes are a bit shagged. If you plan on being serious and not just a a "low scene kid" a full front end refresh kit is worth it. foff did a full refesh and his car was slammed but drove like it was new.
    Oct 2012
    Second Water boys comments but also check whats already there. My front wishbones already have poly bushes that look like theyre in pretty good nic so hopefully theyre ok at the moment.
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Jan 2013
    Redfern, NSW
    I'm not sure what is gone specifically. Two corners, one front, one back, are pogo'ing. I want to reduce the ride height as it looks awkwardly high atm, and I also want to improve the handling. I'm spending a lot of effort maintaining the original comfort of the ride and sound as well so don't want to sacrifice that. Is that asking too many things?
