coding radio
Guys,
Don't have an owners manual and I need to recode the radio.
I have the code, (although I have 6 numbers on the paper that I got with the car) I just need to know the button pushing sequence.
Thanks in advance.
Ross.
hey,
if it's the standard eurovox unit this may help, its from the eurovox site.
Turn ignition key to 'Accessories' and a number '1' or code '1' or similar will appear. Press corresponding preset buttons as you read you security code. If you have a 6 digit security code, the display will count the preset buttons pressed. i.e. display will show '1' the '2' then '3' and so on up to '6' regardless of which number is pressed. If the security code is correct, the radio will turn on. If the security code is incorrect, the display will show '2' or 'code 2' or similar. After 3 incorrect attempts, the radio will go into 'lockout mode'.
cheers
sam
Sam,
Thanks , that's exactly what I needed to know.
Ross.
Did it work out? I have an eurovox instruction manual which could help if not.
1995GolfGlRocketShip!
- You may not post replies
- You may not edit your posts
Forum Rules
