Results 1 to 6 of 6
Thread: CLutch Pedal - Hydro
    Feb 2006
    Camberwell, Victoria
    Alrighty, I'm half way through a swap from a 020 cable box to a 02A hydro box...
    I would like to get some pictures of the clutch pedal from side on to see how the clutch master attaches to the clutch pedal...
    If someone can fill in the gap it would be great!!!
    THANKS!!!
    Apr 2006
    Hobart,Tas
    There is a plastic piece inside the pedal that clips onto the ball on the pushrod. It is very easy to break this piece when removing without the vw tool. Even then they are a pain. Reckon you should be able to buy new piece (genuine only)
    Apr 2006
    VW Race HQ - Sydney
    Its a pain even with the VW tool . Last time I checked you cant buy the plastic bit seperate , you have to buy the whole pedal
    Apr 2006
    Hobart,Tas
    Glad to hear I'm not the only one that has problems removing them with the tool! Easy to bend the tool to!
    Camden, Sydney
    Happy to oblige with a pic. Here is an assembly out of the car.
    Picture one shows the pedal and the master cylinder. pay particular note to the pedal itself, which will be different to your one and the bracket that holds the cylinder against the firewall.
    You will need to fabricate such a bracket and modify your pedal, of fit a VR6 pedal box.
    Picture 2 is a close up of the plastic thing that is easy to break. If you have two blokes with a screwdriver each and you push a side in each, you can manage to not break it.
    Good luck, keep us posted on your progress.
    Feb 2006
    Cool! (NOT)
    So, where do i get a vr6 pedal box from?
    Cheers Loon!
Similar Threads
  1. HELP! Clutch pedal stuck all the way in...
    By gman in forum Mk3 Golf & Vento
    Last Post: 24-01-2007, 07:33 AM
  2. Clutch Master Cylinder
    By Snoopycrx in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 07-12-2006, 03:37 PM
  3. CLUTCH!!!!!! help... 2E series 8v motor
    By 86gti in forum Mk2 Golf & Jetta
    Last Post: 17-04-2006, 06:52 PM
  4. need advice on upgrading to a bigger clutch
    By mollins in forum Mk1 Golf
    Last Post: 09-01-2006, 07:56 AM
  5. Which clutch
    By Gas in forum Mk1 Golf
    Last Post: 03-08-2005, 05:50 PM
