Results 1 to 5 of 5
Thread: Check Engine Light Gone ?
    Hi All
    I am new here , check out my intro here. I sure hope you guys are nicer then the "new Jetta" section
    Anyway I am going to start with a real dumb question and yes I did try searching and googling etc.
    My car has a rough idle , I am pretty sure its plugs / leads / coil but just to be sure I want to check the fault codes but on my 95 Mrk3 VR6 (pretty sure its ODB I) where is the check engine light ?
    I have a sneaking suspicion its been removed.
    Here is my dash, should it be between the battery and head light ?
    Any help appreciated.
    Sep 2009
    80% sure OBD1 VR6's dont even have a check engine light from factory! My old one definitely didnt.
    aha , thanks for that , so the only way to get error codes is using the appropriate reader ? ........ right ?
    Jan 2011
    Rooty Hill, Sydney
    Quote Originally Posted by LeaMedhurst View Post
    Welcome to the forums man
    yes thats right, in between the battery and hand brake light ! (assuming that strip where all the warning lights are, is the same as a GL).
    Check egine lights only come on when something bad has happened/about to happen that has the potential to screw the motor up (pretty sure of this), so having a rough idle wont bring that light on.
    im pretty sure you carnt get to the back of that warning light strip, you can only change the bulbs i think.
    oh an thats a 98model dash.
    go through the basic catergories (air, fuel, electrical) to figure the problem out.
    and i think tocheck for error codes the only way is using some vagcom cable thingy.
    Garage:
    VR6
    XR6
    R36
    Thanks guys, very friendly and I have to say that the manual VR6 is the family favourite above the new jetta
