Page 2 of 2 FirstFirst 12
Results 11 to 20 of 23
Thread: Changing Suspension
    Jul 2007
    Constitution Hill
    are you askin how long it takes to install suspension?
    for a trained and experience installer it shoudl take no longer than 2 hours; assuming there are no problems. I am talking about a person who is experienced in servicing our veedubs. if they are asking for anymore, its a load of crock. if they are inexperienced, then 300 is alright, given 80$/hr or so.
    as for doing it yourself, it is fun if you have the right tools. you'll definitely need an impact gun, ie air compressor tools. if you don't have the right tools it only becomes frustration. especially if you are half way into the job. then you'll need to put it all back again.
    there are many resources in changing your suspension, it isn't difficult, it is a matter of having the correct tools. you could probably only buy a heavy duty air compressor with $300. but worth then investment I reckon if you are planning to do other stuff.
    btw.. what kw's did you get? it seems although everyone is hooked onto those kw's stuff, not that there is anything wrong with it. what about bilstein and hr stuff? why'd you choose kw?
    Feb 2006
    Camberwell, Victoria
    I can give you a hand if you want. Shouldn't take too long bud!
    I have spring compressors, and a neat little trick with a 22mm spark plug socket, and a 7mm hex key to undo the top of the front struts.
    Rears are a piece of cake, as per my spring cleaning thread, I just did it last week.
    Once they're in, I guess its a matter of getting the camber right, checking the toe in/out, and adjusting the damping and ride height correctly.
    SEAN.
    Sep 2006
    West Sydney
    Quote Originally Posted by cOS View Post
    Value for money I believe! < $2000 for a set of V2's from the guys at InMotive at the moment.
    Jul 2007
    Constitution Hill
    Quote Originally Posted by rayray086 View Post
    yeah you are right.
    I haven't notice many with other setup than kw's. i'd be interested to see who has a bilstein or other coilover setup or other than kw's. it seems although we can only source kw's and nothing else.
    Sep 2006
    Sean I sent you Message
    MODS- TOO MANY
    Sep 2006
    Tim has bilsteins, I think they are over $4000 here and the Konis were $3000, I was going to import some, but seeing as I could get such a good deal here their was no point
    MODS- TOO MANY
