Page 1 of 5 123 ... LastLast
Results 1 to 10 of 41
Thread: Change Heater Core
    Apr 2008
    Change Heater Core
    DIY Change HEATER CORE in VW Golf MK3 VR6 with pictures:
    So I decided to replace my heater core.
    There are a lot of steps involved here but the work isn't difficult.
    First disconnect negative or positive or both from batteries.
    Remove radio/cd/tape player :
    Carefully remove plastics around steering wheel :
    Remove lower glowebox :
    Remove ashtray and cigarette lighter :
    Carefully remove plastic around heater/air-con control :
    When you take out there is 3 plastic clips on the top and one at the bottom. You need to remove them to disconnect all cables from switches :
    Carefully with screwdriver remove two small plastics parts on the right sine from stereo, and after that unscrew two bolts :
    Carefully with screwdriver and fingers remove headlight euro switch and plastics with ABS and airbag lights. Disconnect all cables carefully :
    R36 > MK5 2006 1.9 TDI > MK4 2003 1.6 Generation > MK3 1995 2.8 VR6 > MK2 1990 1.6 > MK1 1982 1.8 GTI
    Apr 2008
    Remove foam under lower glowebox. There is 2 or 4 bolts:
    Carefully with screwdriver remove all 4 plastics for ventilators:
    On the passenger side remove 2 bolts under plastics (next to speaker) :
    Remove 4 bolts where is stereo :
    Remove tacho (2 bolts) :
    Remove 4 bolts under euro light switch :
    Apr 2008
    Remove plastic cover around handbrake. There is 2 plustic nuts 10mm and two bolts :
    For easy removing plastics just remove 2 nuts 13mm for hanbrake, but first deactivate handbrake :
    Unclip all plastics with fingers or just a little bit help with screwdriver:
    Remove 3 plastic nuts 10mm :
    Thre bolts for removing passenger airbag :
    Apr 2008
    Carefully disconect airbag. Mine connector is broken because light for airbag is on all the time :
    Blue one is for plastics removing around fuses and relay, and red one for dash :
    Now going outside to remove wipers 13mm and after that 2 pieces of plastics with screwdriver and fingers :
    Remove 3 nuts 10mm for easy access to nuts for dashboard :
    10mm nuts for dash :
    Spy 10mm nuts under metal shield :
    Apr 2008
    First unclip plastic which hold polen filter, and second remove 2 plastic nuts 10mm to remove all plastic. Will be surprised how many dust and rubbish around :
    Red one is for dash and blue one for lower glowebox :
    Carefully take out all dashboard.
    You need to unclip all plastics cable holder around stereo, and 2 connectors for left and 2 connectors for right speakers :
    Blu bolts is for removing metal barrier:
    Apr 2008
    Disconnect air-con next to blower :
    Remove metal gold clips all around (about 10 clips) to separate heater and aircon :
    Unclip all cables :
    Unclip vacuum hose from aircon to heater :
    Apr 2008
    Remove 2 plastic nuts 10mm which hold white "BASKET" :
    Remove side plastic trim for easy pull off metal bar :
    Pull out metal frame about 10-20cm :
    Go to engine bay and remove two nuts 10mm and one in the middle with allan key to disconnect aircon :
    Apr 2008
    Remove all 3 metal clips with screwdriver and after that move little bit left or right to remove metal for adjusting heater/aircon :
    Apr 2008
    Disconnect vacuum hose from heater core from engine bay, but carefully I broke mine :
    Back to car and disconnect jack on right side heater core and remove with screwdiver :
    Apr 2008
    Now with screwdriver (around 4-5 bolts) separate blower from air-con.
    After that take blower out slowly because is small foam gasket between blower and aircon unit.
    Separate aircon unit from heater unit (small metal gold clips), there is another foam gasket - be carefully.
    Take out first aircon unit (bigger one on passenger side), and after that heater unit.
