The system has a pump and air lines, if the pump is running there is a leak/break in the air line.
If it was the pump the fix is pretty quick and simple, if it's a leak it means checking all the lines till you find the problem.
What a lot of people do is to replace the air system with an electric system which also means you can get remote central locking
At the end of the day the actuators are cheap, it's the install that will cost you (unless you DIY).
