Results 1 to 7 of 7
Thread: Center Cap size for 15" VR6 BBS rims
    Oct 2010
    Melbourne, VIC
    Can anyone tell me the size of center cap needed for the 15" VR6 BBS rims
    Ones that look like below
    Thanks in advance
    Resident grumpy old fart
    Mar 2014
    Bundoora, Victoria
    OEM code is 1H0 601 171 B
    Just measured mine and they are 55mm.
    Past - '95 VW Golf MK3 VR6
    Oct 2010
    Melbourne, VIC
    Thankyou very much. I have been trawling all over the web to find this info and your post is the only definitive answer on this.
    Now to find some...
    Mar 2014
    Bundoora, Victoria
    I just bought some caps advertised as 56mm outer and 52mm inner (the inside clips) and they fit perfectly.
    They are BBS replica caps, so looks like 55-56mm caps work.
    Aug 2011
    hi mate, also looking for these.
    where did you end up getting the replica caps from?
    closest i found were: 4 Carbon Fiber BBS Racing CAR Alloy Wheel Center HUB CAP FOR BMW Audi VW 55mm | eBay
    but they are "60mm outer in diameter, 55mm outer clip to clip insert diameter."
    thanks
    2010 Jetta 125TDi DSG
    1994 Golf VR6 Manual
    Mar 2014
    Bundoora, Victoria
    The listing on eBay isn't up anymore but the title for it was: BBS CARBON 4 x ALLOY WHEEL CENTRE CAPS 56mm 52mm
    The seller also isn't selling anything anymore.
    Aug 2011
    ah damn, thanks for the update anyway mate.
    may have to get these and stick them on top of the stockies...
    4X Emblem BBS Racing Wheel RM RS Nissan Center HUB CAP RIM Decal Sticker 56 5mm | eBay
