like the chassis?Can't wait till u start replicating OEM parts so you can replace the old with the fibre and do some crazy weight reduction.
87' MK2 GTI
13' MK7 TDI
80,000km 1997 MK3 VR6 manual for sale - www.vwwatercooled.org.au/forums/f23/80-000km-1997-manual-vr6-nsw-sydney-67658.html
2010 Reflex Silver MK6 Golf GTI
Sunroof - MDI - Superchip - 19" VMR V710 - Kuhmo Ecsta SPT KU31 - VW Racing Panel Filter
Replacement parts would be a an expensive challenge, the hardest process would probably be the attactment fabrication. Replacement for weight saving purpose would be impracticle, I have read some where for the mk3, for every ~70 kg weight saved would gain 1/10 of a sec in a quater mile run.
a meter square of carbon plus 1.5 liter of resin cost me $140 that weights about 2 kg all up
if my maths is right ...To replace 70 Kg with carbon would cost almost $5000.. remember that would only gain 1/10 of a sec in quater mile.
I think $5000 spent on a super charger would be more worth the money. LOL .
+ to have any structural strength you would need at least 5-6 layer of carbon coats, which means all $ for **** all. 1 layer of carbon I crush with my hands.
I am merely using carbon as an alternative to paint. ideally if time an money permits I would want to overlay all my exterior black trims with carbon. I am sure I wouldn't miss bumper blacking every wash.
initially I want more shine to have a distintive effect Bling Bling appeal. but I think differerntly now, from a distance it looks it has been painted black but only close up it shows the carbon effect. Stealthy I say..
What is your suggestion ray ???
Just hope the tape is reliable and it wouldn't give.
an more cost alternative to that could a 2 part mold, with black gel coat, so the product woud come out shiny and black with original size. The only problem is to make a perfectly straight mould, otherwise it would not attact properly.
BTW I still have endless supply of fiberglass ~50 + meters worth if anyone needs it let me know.
Keep an eye out for a vacuum pump.
Find a mate who goes to uni (or yourself if you go to uni) and get him to check out all the skips around engineering/medical departments. In the last few years i've seen probably 3 or 4 pumps in the skip, and probably only because they are old, and using a bit of oil.
I'm sure a bit of vacuum film doesn't cost that much..
Then again, if you're getting a good finish without Vac, then why bother? Only for non-structural though, of course.
Peugeot 306 XTDT 1.9 Turbo Intercooled Diesel
1976 LS parts vehicle
Used to have: Mk1 Swallowtail LS DIESEL!
