Results 1 to 2 of 2
Thread: Car won't starts
    Apr 2013
    Central Coast
    Car won't starts
    Okay so I've just installed air life suspension, everything was good I've driven it a few times today.
    I have the ignition from the air lift plugged through a 3amp fuse straight to the ignition wire under my steering wheel (as far as I know that's what the wire is??)
    Now I've just gone to start my car and there is no dash lights or anything and the car won't start. Friend said check ignition fuse but I looked that up and as far as I know mk3 doesn't have one?
    Anyone know the issue? Cheers.
    '98 Golf Mk3 4 Door
    Mar 2014
    Bundoora, Victoria
    Have you checked the battery? Sounds like it got drained overnight...but that shouldn't be the case if it's plugged into ignition wiring.
    Tried disconnecting the air life suspension system and starting? At least you would eliminate it from what could be causing the problem.
    Past - '95 VW Golf MK3 VR6
