Haha every thread is turning to rubbish with because of google images.
We get the point guys. Back on topic please
Canadian dubs coming to VWwA soon
Bahahaha OK OK, i get it!!
I'd already figured the front needed to go down, but was pretty happy with the back? Maybe ill drop it a tad more just for you guys
No rubbing issues at all so far ^_^
Oh um yes and errr, got a lowering tool with the coilovahs, but NFI how to use it???
Is the tool like a pirate's hook? There should be notches on the spring perch in which you can catch on to with that tool, and you should be able to spin the perch with it. There's usually a bolt that loosens and tightens the perch, usually one that requires an allen key.
Yes yes, the pirates hook. So far its proved very useful as a back scratching tool!
No idea on the allen key bit, will have to take a look.
Can you make lowering adjustments without jacking the car up??
no, you realy need to take the weight off it. And it easyer with out the wheel on too.
Oh... gay.
I only want to drop the front a smidgen... maybe 1cm? If I could just tap down on the bonnet until it was where I wanted it.
and why cant it be like on need for speed? Tap up and down to adjust the height...
