Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: can anyone help.......fairly urgent....
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    Guys,
    the mrs has the car and the rear window doesnt go up. im assuming its the regulator, is there anyway of getting the window to come up or do i have to take the door apart and try to lift it myself.....please help!!!!!!!!! so annoying im at work.
    thanx
    Aug 2006
    Skye, Victoria
    dropped all the way down? if so you'll have to remove the door trim.
    if not grab the window from both sides with your palms and push up at the same time as pressing up on the button.
    works for me.
    Feb 2007
    will give that a go, if it doesnt work, if i take the trim off, can i get it up that way?
    Sep 2006
    Banff, Canada
    Quote Originally Posted by BlackVr6ix View Post
    works for me.
    I'll second that.
    When my driver's window went it dropped all the way down, but the pulley wired caught the regulator for an instant (I was playing with it trying to get it to work) and it popped into view. I grabbed it and applied upward pressure with my palm when I had enough window, while pressing the button, managed to get the window to slide up and stay in place...
    Every situation's different. ALL are painful
    With the trim off, it's a piece of cake. Just make sure you have a helper and a lump of timber handy (to keep the window from falling back down)...
    I feel for ya
    JHN
    Canadian dubs coming to VWwA soon
    Feb 2007
    OMG, she just rang me up and told me the car overheated.....the water temp went past 110 and she said she saw steam coming from where the expandion tank is? what the hell is going on. ive changed most of the hoses, the thermostat and its housing..........what could be causing this? this happens only sometimes and i always managed to turn it off before it overheats...could it be the relay. if so anyone know which one? waterpump? someone please give me some guidance.....
    Sep 2006
    Australia?
    I changed my water pump over the weekend that could be the cause of it!
    Feb 2007
    anyone else have any ideas?
    does the waterpump just stop working or does it gradually die? would it be more likely to be a relay? does anyone know which relay it is?
    Aug 2006
    Skye, Victoria
    sounds to me like the secondary water pump has failed.
    Sep 2006
    Australia?
    Water pump is common to go on our cars, change it and all good
    Feb 2007
    what makes you say its the scondary waterpump? Im thinking it could be the fan switch relay?
