This part is broken on my rear window, do all windows use the same "window claw"?
I thought I might see if I can get one from the wreckers.
Also, how do I go about getting it to pop back in?
I made sure it would not be resting on the glass, the bolt acts as a stop for the clamp, the clamp rests on top of the bolt.
My stopper is still in the metal slide and works fine up and down, I need to somehow get it into the window clamp, but I think the window clamp is broken and no longer holds the stopper.
Hopefully I do just need to tighten up the clamp, can't really live without being able to open the driver's side window...
Past - '95 VW Golf MK3 VR6
Not exactly sure but does this help?
VWVortex.com - window regulator diy
Have done this to one of mine, so have a lot of others
Calling NSW Mid North Coast VW Enthusiasts - Click Below
Mid North Coast Dub Club
Cheers, I actually didn't think to remove the window claw from the window before removing the regulator assembly...
i will make sure to do that and attach the window claw like the DIY.
