Page 1 of 4 123 ... LastLast
Results 1 to 10 of 39
Thread: A/C pain thread!!!
    Sep 2006
    Banff, Canada
    Angry A/C pain thread!!!
    Took my car to Australian Continental Motors today, as Claus is a master on German cars, and he does A/C.
    With summer on the way, aircon is a fantastic thing to have, yeah? Sure... if it works. Mine, however didn't. No worries, i'll take it to get fixed. Claus pressure tested it today and found some disturbing problems -
    1. Blocked and corroded TX valve ($190)
    2. Blocked reciever-dryer ($150 or $115 - Claus can be hard to understand, it's the genuine German accent )
    Both need to be replaced, some seals repaired, vacuumed, gassed and resealed. Total $600 PLUS!!! I was supposed to get the car back fixed tonight, but the TX valve has a frozen bolt, so i'll have to wait until tomorrow now... I MISS MY BABY!!!
    OK, here's why I wrote - Claus has given me some invaluable information that i didn't know until he told me...
    It is not often a problem during a hot summer, when A/C systems are used almost daily, but it is imparative that VW A/C systems are run AT LEAST once a week, even during winter, even if you run them on heat, as long as the A/C is running. The seals inside the system dry up very quickly and become brittle if they are not exposed to the A/C oil regularly. On top of that, the abovementioned parts block easily unless the gas/oil is circulated throughout them regularly. And believe me, the repairs are expensive!!!
    Having made the mistake myself, i offer you guys my newly aquired knowledge so that you won't make the same mistake i (or the previous owner) made. An aircon regas costs under 200 bucks, but you can spend the better part of a thousand dollars if you neglect your systems needs.
    Sorry if something similar has been posted before, but i am so upset about how much my porta-antarctica is gonna cost me, you guys shouldn't have to cop it too...
    Cheers all. John
    Canadian dubs coming to VWwA soon
    Apr 2006
    Carlton, VIC (HK now)
    John... don't worry, mine was having bit of leak as well and it needed a bit of welding and regas... 200bucks and still the aircon is like...sxit... however I won't use it much unless its 35 above, engine just ain't strong enough to run with A/C
    Carlson
    Sep 2006
    Australia?
    Quote Originally Posted by Golfer
    Cheers all. John
    Excellent info there John thanks for the heads up on that. I usually run my air con at least a couple of times a week after a wash my car instead of putting down the windows I put on the a/c. I never knew that before so thats awesome. My heater wasn't working in my previous vr6 and they wanted something like $1400 to fix it and I only had that car during the winter . Make sure to keep us up to date to see what happens after you get it back.
    Jun 2006
    thanx for sering that with us, i never used mine but now ill make sure i turned it on now and then to keep it running
    its not a good feeling when u have to spend serious $ to make one little thing work
    even tho i dont use mine unless my windshield is seriously foggy for some reason or when is 35 and up, the fact that there is a piece of machinery in the car that is not operating is what eats me alive
    cheers
    Jul 2005
    Melbourne, Williamstown
    Fortunately or unfortunately it's not a only VW related problem as I think most vehicle a/c systems suffer from the same problem.
    Never the less invaluable info for those who don't know.
    mk2 GTi 16v
    Corrado G60
    Oct 2006
    Bugger that! I was just thinking that mine needs a regas, I hope its not that bad
    Apr 2006
    ahhh...btw does anybody have a problem with the recycling system as well?? mine doesn't work !! just blowing dust onto my face...
    Sep 2006
    Banff, Canada
    No worries guys, It hadn't really worried me until my drivers power window gave up the ghost, and then we had a spate of really hot days... not cool! (apologies for the pun ) so i realised that in this part of the world with high heat and high humidity it's not great if you can't escape it. Throw in a couple of traffic jams, and an afternoon thunderstorm, and i was sold on getting the A/C fixed. The cost was, um, rather unexpected. Nevertheless i'm sure that as soon as my new window regulator arrives from Andrew, i'll whack that puppy in, crank down my beloved window, and only use the A/C (to full effect) when i can smell my arm hairs burning . You can be damn sure though, I'll be running that sucker religously from now on once or twice a week!!! 600 bucks... pfft
    Cheers, John
    Jan 2006
    this sounds like doom for me, after spending $1200 on a new compressor and everything else for the polo. My Golf has just decided it doesnt wanna blow cold air. I live in Brisbane and drive a lot...I need cold air. I will regas first and hope(and pray) for the best.
    brackie Guest
    Lack of maintenance = big $$$s
    All types of refrigeration require frequent running to keep the seals in good order. Oil is circulated with the gas and this keeps the seals soft, lubricates the compressor and provides extra sealing at the lips and "O" rings. It's essential that you run the compressor regularly throughout the year in order to keep the oil moving. If you do this then the system will run trouble-free for years and as long as there's no mechanical damage probably outlast the engine. The receiver/dryer will need replacement as time goes by but will last for a hell of a time as long as you run the compressor regularly. TX valves usually fail because they get clogged with *****.
    We have 2 milk vats on the farm and a visit from the fridgies never comes at less than $750 so it's in our best interests to keep things in good order. They never spew a problem during the milking season as they run every day so our policy now is to run them at least once a week when the goats are dried off during winter so that they can go straight into service in the spring without a problem.
    Think of your fridge in the kitchen and the number of times a day it kicks in and out. Your air conditioner n the car works on exactly the same principles.
Similar Threads
  1. Mk3 Exhaust Thread!!!
    By Golfer in forum Mk3 Golf & Vento
    Last Post: 20-03-2007, 09:36 AM
  2. thread of shame
    By gldgti in forum Mk1 Golf
    Last Post: 14-03-2007, 12:53 PM
  3. Useful Description on Thread Titles
    By mikinoz in forum User tips and Forum Suggestions
    Last Post: 23-02-2007, 03:39 PM
  4. Massive Mk3 Picture Thread!!! (bye bye 56k)
    By golf3 in forum Mk3 Golf & Vento
    Last Post: 11-09-2006, 10:04 PM
