Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: Buying A Vr6
    GEELONG
    Buying A Vr6
    Ok...........Guys.
    There are 2 VR6's on the car sites in the $5500 to $6500 price bracket with K's 200000 plus.
    Is one buying a **** load of trouble buying one at that end of the $ chain?
    What should one be aware of when buying a VR6?
    Thanks.Doublecab.
    Feb 2007
    Perth, WA
    My VR6 has 242,000km on it besides standard upkeep and servicing, there have been no major issues for me.
    I also thrash the pants off it
    Feb 2007
    Bunyip, Victoria
    I know of a few VR6's getting in the higher reaches of Km's, and they do seem to need alot more work than mine has ever needed. Mine has 140,000 on it, so i have a bit to go before the magic 200,000 km.
    Im not too worried about large k's. My last 2 cars had 340,000 and 314,000 respectivly, and didn't require any special assistance.
    May 2006
    There were at least three model versions of the VR6. <1994, <1996, >1996
    Mine is a 95 model and has 250k+. It has been extremely reliable mechanically. On the other hand the very expensive electronics are trojan horses. ABS, Cruise Control are "Go Lo" quality. Many owners have had bad experiences with coil packs and electric windows too.
    The other component set that wears quickly enough are the shocks/struts. Their life is 60k. And sooner or later there's going to be some very expensive fuel pumps to change and the little plastic and rubber bits in the engine bay that suffer from heat and oil vapour will leave you wondering how VW ever managed to sell these cars under $150,000. We badly need more interest from after market manufacturers but with barely 250 cars landed here in the first place its not going to happen.
    Towards the end of 95 there were some important improvements beneath the skin to the electronics and suspension. I can't comment on whether these fixed earlier problems.
    GEELONG
    Ok if one went over to a Passat Vr6 would it have the same issues?
    May 2006
    Yes you just have to know these things are part of the ownership equation. In fairness to VW the problem is really caused by their external suppliers. VW shares these suppliers with other companies so its not surprising BMW is also known to have a problem with electronic components. There are reports that Volvo have had similar issues.
    It should be said too that the VR6 parts prices are no worse than those for any other VW. And a lowly Polo part may be even more than a comparable Merc bit. VW is very democratic about that stuff. Truly a peoples car.
    Feb 2007
    Perth, WA
    Aus liebe zum automobile
    gpk_gti Guest
    seems to be a good time to get yourself a vr6 bargain,but from what I hear around the traps,vr6's are going through a tough time(clutches,blown heads,fuel pumps,pipework,electrical issues) they are getting old and high k's are bringing all those issues out.check the car thoroughly before purchasing.check with golf loon,he is our resident vr6 expert..
    Feb 2007
    im a pom from the UK, but am living in Oz for a while...
    Only buy one if you have money to burn....or be prepared to be burnt!
    Sep 2006
    Australia?
    There are really good examples around and then there are crap ones, I should know my first was a dud! Just make sure that all is working properly and there is no leaks from pipes, WATERPUMPS, thermostat housing and anything else that you may find needs attention!
    Also I would rather buy a vr6 that had higher kms as a result there is a chance that things have been changed and not about to go with lower kms cars!
