Page 1 of 3 123 LastLast
Results 1 to 10 of 21
Thread: busted oil pump and pan vr6
    Sep 2007
    perth western australia
    here is the short story !! i drove over a bump last night in the vr6 , , the suspention is low , knocked in the oil sump and think the oil pump is damaged as the oil light was flashin , i idled home for a about 2min , hopefully i havent damaged the engine i hope i can just replace oil pump and pan , and see how it goes , anyone here had the same problem ???
    Sep 2009
    my pan and pump are also currently ****ed havent driven the poor car in a month as i havent been able to afford new bits -.-
    Jul 2010
    qld
    am constantly bashing the crap outta my sump, never damaged anything that much (yet)
    Radiators are over rated
    Jan 2008
    Newcastle, NSW
    germanautoparts I got my replacement sump, magnetic plug and copper washers from. You'll get them cheaper than what I did too.
    Can't recall if the pump was there or not, though i'd take a punt and say yes!
    Sep 2009
    mine took a good 6 months of abuse, being <2 inches off the ground (alot of the time, lower then that ) but finally took one hit too many and cracked the pump and pan pretty bad :/ good time for a r32 sump/pump conversion to put it above the subframe though
    Sep 2007
    Quote Originally Posted by sortofbigbj View Post
    i just think there could be damage , the engine isnt sounding too good , lack of oil getting to the engine ........did your oil light ect come on during your episode ??????
    Sep 2009
    my oil light would come on around hard corners/up steep hills, which made sence when i dropped the pan and took a look, i could hear a slight tick while driving with it broken but it may have been in my mind. If its making noise and you have the oil light on I definately wouldmt be driving it until you check it out...
    heres a pic of my pump
    Hopefully no serious damage has been done too your engine and its not too late.
    Sep 2007
    cheers for the support , first thing to do next week , and get it to the mechanic .......
    Apr 2011
    Might sound silly, but has anyone ever made a bash plate for their car?
    96 VW VR6 Golf (Daily driver)
    65 VW Beetle (Under restoration)
    Quote Originally Posted by Weeds View Post
    You can buy replacement metal skid plates, which I assume would work to help avoid to much damage underneath the car.
