Results 1 to 7 of 7
Thread: build codes for mk3 golf?
    Feb 2010
    Im trying to buy a set of coilovers, I have found a set that says suites All mk3 golf. I have a 94 VR6 and just want to make sure these will fit before I buy them this is what its says.
    Part fits to
    Volkswagen Golf 3 type 1H / 1HXO / 1E / 1EXO, year *09/91 - 09/97
    without Syncro and variant
    all engines
    I just don't understand the 1h 1hxo 1e 1exo part.
    Dec 2008
    Sydney/Canberra
    1E is Mk3 Cabriolet.
    1H is Mk3 everything else.
    Not sure what the XO is.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Feb 2010
    Thanks man so they should fit?
    Mar 2012
    Central Coast, NSW
    If they say they'll fit a mk2 or mk3 then they'll fit. All the same.
    Jul 2005
    Try fitting 4cyl front springs in a vr6,too soft and too low.Make sure the fronts are for a vr6.
    Widebody Cayman S Turbo, 83 ur Quattro
    2000 996 C4 cab,12 Scirocco R OEM+ STG2+
    72 914 (3.2S boxster pwr), 92 G60 Corrado
    76 Scirocco(TFSI and DSG) 2018 Tiguan,Eureka,81 924.
    Feb 2010
    Thanks guys I asked and they said it was fine for vr6, so ill see what happens.
    Q
    After playing with GL Golf, VR6 Golf, GL Vento, VR6 Vento, GL cabby, they do vary quite a bit, Vento/cab are heavy in the butt, VR6 heavy in the front. But yeah like APRR32 said, just double check those front ones. Then again if they have enough adjustment it doesn't really matter, my car is heavier in the front and back, but has Ray's GL's old coilovers in it and can go to 4WD height and Hannah Montana low.
