Results 1 to 7 of 7
Thread: MK3 Door Locks
    Feb 2008
    MK3 Door Locks
    I have recently busted the door lock barrels on my VR6 and now cannot lock my doors. It happened a couple of months apart...the drivers side going first, then the other side today.
    After a nasty little snap within the lock I can no longer lock or unlock the car from the outside.
    I would like to be able to lock my car, does anyone have any insights into the best way to repair these?
    I was thinking this may be a good time to upgrade to keyless entry, is there a good cost comparison between this and just repairing the barrels?
    Hope this helps
    http://www.vwwatercooled.org.au/newf...ad.php?t=18656
    YOu can contact Golf Loon for a second hand eccentric "hook thing" or a "heavy duty aftermarket set for ~$80 from Tooleys imports honsby.
    A keyless entry is also about the $80-100 mark with the flip key fob.
    Feb 2008
    Thanks
    Thanks SoundofaV6, that does help.
    The installation looks pretty straight forward, is it basically the same for the keyless setup?
    Dec 2006
    Kilsyth, VIC
    Keyless is basically 4 wires spliced in at the vacuum pump in the boot. It's easy as, but either way I would be fixing the door locks, you never know when you will get a flat battery (or more likely a busted vacuume pump) and need the key
    Camden, Sydney
    I also have the new lock eccentrics for you car in stock $20 each.
    Mar 2007
    sydney
    Quote Originally Posted by Joe88 View Post
    I propose a sticky common faults thread for the mk3 section, this problem and others have come up so many times...
    Locks spinning...
    and a little less often
    Window regs dieing
    Front lip replacement
    Air con
    ABS failure
    Sloppy gear change
    Rocker cover gasket
    what am i missing?......
    any thoughts on this idea?
    heater core oh i loved my mk3 but glad its gone
    mk4 the mods begin for round 2 hahahha
    Feb 2008
    Cool, how do I order from you to send down to Melbourne. Assuming I only need two for the front doors?
