Results 1 to 8 of 8
Thread: break pads change problem :(
    Jun 2006
    iwe changed so many on other cars, and front on this one but rear ones wont work with me
    the "piston" wont go back so i cant place the new pads in and while messing with it i managed to press the pedal that handbrake is connected to which pushed the piston even further and now i cant even fit the old skinny ones in.
    there is no enough men power that i can produce to push it back, not even with the tool for it
    what do i do, cant even drive it to mechanic now
    Subie25L Guest
    I don't know much about VW's but some cars have pistons that need to be screwed back. Not sure which way though. No matter how hard you push you will never get them back unless you screw them
    Apr 2006
    Hey DeemoIII
    Dont know whether you have drums or discs at the back, but if its discs then try this site
    http://faculty.ccp.edu/faculty/dreed...akes/index.htm
    comes with pictures
    VW Golf MK3 1.8L
    Mini Tanks
    brackie Guest
    Bleed nipple
    I'm not familiar with the Mk3 setup, but what I've done in the past when I've had difficulties is loosen the bleed nipple. This allows you to push the piston back.
    Jun 2006
    Quote Originally Posted by Subie25L
    i think i like ur thinking
    it does have this funny cut-ins, might be that
    tried bleed off, took the bloody caliper off all the way thats how desperate i was
    thnx for the site, thats exactly what i need to do
    im gonna go n try screwing them back
    They defo screw in. The cut out are to fit the windback tool but you can do it with a pair of pointy pliers etc.
    If you have pumped them right out, I would peel back the rubber boot and grip the edge of the piston and turn it using some molegrips or pipe grips. I can hear groans but as long as you get the piston above the rubber then it won't cause any problems.
    You have to screw them back in while keeping pressure on the piston to move it back at the same time. Is a little bit tricky but can be easily done.
    I use some multi grips & a brake piston resetter like this one.
    You could also use one of these
    Or buy a universal kit.
    Jun 2006
    thanks guys, that was the problem
    i used the clamp to keep the preasure on it while skrewing it
    i wouldnt think of it if u guys didnt mantion, first time i heard about skrewing them back in
    cheers
Similar Threads
  1. 95 Ibiza Window Problem
    By VdubDownthePub in forum The Lounge SEAT
    Last Post: 01-03-2007, 03:17 PM
  2. VR6 thermo fan problem
    By Oli in forum Mk3 Golf & Vento
    Last Post: 15-02-2007, 06:28 PM
  3. Replies: 9
    Last Post: 11-02-2007, 05:58 PM
  4. new deck install problem...help
    By deemoE36 in forum Mk3 Golf & Vento
    Last Post: 13-01-2007, 11:01 PM
  5. Brake Pads
    By el_foolio in forum Tuning and Performance (inc ECU upgrades)
    Last Post: 17-06-2005, 11:28 AM
