Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: Brakes and Bolts
    Oct 2012
    Quote Originally Posted by KI11Z View Post
    brakes are easy bro, jack it up and get it done, you'll be fine..... as for the bearings, if you don't have a press, get your taptap on with a hammer, slowly moving around, bit by bit with removal and installation. also a rattle gun will help with the axle nut, other wise get someone to stomp the brakes whilst you crank it....
    shouldn't be any need to bleed the lines though? unless you're doing the fluid too?
    side note to the torquing too, always nip it after it clicks....
    Cheers mate! Will order the parts later this month. I'm going to replace all the lines hence the need for bleeding but should be pretty straightforward with the Dad or Brother pumping the pedal!
    Still have the jolt in the steering wheel... I have tightened and checked everything and just can't figure out why it jolts when I accelerate. Might have to take it back to the alignment guys AGAIN and get it done, it definitely feels like I can turn left easier than right so maybe the camber is out.
    Current: 2007 Black Magic GTI - APR Stage 2, Carbonio intake, APR downpipe and catback exhaust, RNS510, Bi-Xenons, Custom Red Leather Interior, Tow Bar, Racks and Parking Sensors
    Previous: Absolute Red 2000 S3 8L - Stage 1 Custom Code
    Previous: 1997 Black Magic VR6 - CX Racings, BFI Stealthlines, Chipped ECU, Genie Extractors, Thule 404s, Fairing, Suitcase delete with hotdog.
    Sep 2006
    Parkinson / Brisbane
    jolt as in a knock??
    Oct 2012
    Nah as in when I accelerate the steering wheel turns left about 10 degrees.
    Mar 2014
    Bundoora, Victoria
    Quote Originally Posted by mb1907953 View Post
    This happens to me also, but not always.
    Past - '95 VW Golf MK3 VR6
    Sep 2006
    not just a case of torque steer?
    Mar 2014
    Bundoora, Victoria
    It think it always happens when I put my foot down, so torque steer would explain it.
    Aug 2007
    You have to tighten that control arm bolt when the susp is pressed.
    Alba European
    Oct 2012
    Quote Originally Posted by Jmac View Post
    Jimmy to the rescue! Will give this a shot. So loosen off and then retighten? Or just tighten again once its on the ground?
