Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: brake down
    Point Cook, Vic
    yeah buy it from a dealer and pay $250 or whatever they charge. it will make u feel all warm and fuzzy inside
    FOLLOW US ON FACEBOOK
    syncro Guest
    Can someone give me a loan of an old defective coil?
    I would just like to see why they fail and see if there is a temporary fix.
    Sep 2006
    Banff, Canada
    I had the same problem with my GL when i first bought it, and found that i had water in the dizzy, and all it needed was a dry out and a spray with **** smiths electrical spray (like a solvent based water dispersant). Sometimes you cant see the water at first because it could be out of site so give it a good spray and leave it a while to dry out).
    The problem i had was literally identical to what ur describing...
    Hope this helps (could be a simple and cheap alternative to replacing the coilpack)
    John
    Canadian dubs coming to VWwA soon
    Camden, Sydney
    Quote Originally Posted by syncro
    Its the plastic housings that crack and then they arc across the gap. I have repaired them temporarily with araldite and silicone, but they always break again.
    I threw about 4 broken ones out last week
    Camden, Sydney
    DemoIII came down here today and grabbed that coilpack. Did it work Demir?
    Jun 2006
    Thumbs up
    Quote Originally Posted by Golf Loon
    yeah, plug and play, the problem was solved, thanks Matt
    but the broken one didnt crack like u said, i guess its internal
    im impressed with the work u r doing, and have done already lookin good men
    thanks for helpin out today, cheers
    thanks for all ya put in on this post guys, was helpful
    o, and its Demil (its alright, happens all the time)
    Camden, Sydney
    Sweet. Glad it fixed it. Good to see you today Demil. See you at the cruise.
    syncro Guest
    If you get another dud coil Matt, keep it for me.
    Oct 2006
    sydney
    on that topic u can have my old coil and generator, i have had numerous problems with coils for mk3s there are two different types a solid block amp bremi coil and the newer beru type i went to hanvic puchased a bremi unit at $150 it didnt come with the generator on the back so used the old generator of the coil started ran for half a day then died i brought it home then i thought fuel pump but then realised it had no spark traced it back to the coil in the end i had to buy the newer beru one that is a complete unit for $150 stil trying to get my money back for the other one
Similar Threads
  1. Brake reservoir lid
    By gman in forum Mk3 Golf & Vento
    Last Post: 14-01-2007, 01:05 PM
  2. Brake problem for Safety check
    By TYPE 17 in forum Mk1 Golf
    Last Post: 02-12-2006, 07:26 PM
  3. Audi S3 brake upgared (Caliper painting)
    By PoloGTi in forum Polo (9N & 9N3, 2002 - 2009)
    Last Post: 26-11-2006, 01:42 PM
  4. Golf Mk1 brake confusion
    By tassie_euro_mk1 in forum Mk1 Golf
    Last Post: 21-07-2006, 05:47 PM
  5. A brake story...
    By imported_brackie in forum The Audi Quarter
    Last Post: 23-05-2005, 10:20 AM
