Leak......help!
Just found a leak coming from the front of the engine. It appears to be coming from the thermo housing or the black plastic pipe (ive heard it refered to as the crack pipe).
1. Would anyone know where exactly it would be coming from or can anyone suggest where i should go buy these bits from. I am in the western suburbs of sydney.
2. I read here that its a big job to replace the thermo housing, do i need to pull off the front panel, radiator and grill??? what else needs to come off?
3. are there any special tools required?
4. how long should it take and any special prcedures?
Thanks so much for your help.
Help needed
When's somebody gonna help this guy
If this is a VR6 jump on vortex and search "crack pipe" there are a few companies that do a kit with a metal "crack pipe" which solves majority of the problems with this kind of leak.
Dont worry guys, i PM Golf Loon and i know what needs to be done....im gonna take it to a mechanic!!!!!!
- You may not post replies
- You may not edit your posts
Forum Rules
