BMW alloys??
Does anyone know if the PCD of BMWs are the same as Vdubs? Do you know if BMW alloys fit onto the VR6 or would adapters be needed?
Some BMW alloys will fit the GL-spec Mk3, as I think the E30 or E21 had the 4x100 pattern. However, they were the only BMWs that had the 100mm PCD. I don't think there were any BMWs in 5x100 configuration. They came in 5x120 I believe. Correct me if I'm wrong anyone.
So yeah, I'm guessing adapters would be needed.
you are correct, the BMW rims fit coma-doors.
- You may not post replies
- You may not edit your posts
Forum Rules
