Results 1 to 10 of 18
Thread: Distributor cap removal
    Dec 2013
    Hi guys. My mechanic has told me to take the distributor cap off to let it dry out because I've got some moisture sitting around after the rain we have had in bris.
    The picture below is of the cap correct? Is there a trick to get it off? There are two clips either side.
    Thanks
    Distributor cap removal-uploadfromtaptalk1424909379650-jpg
    Undo the clips and you will be able to lift up the distributor cap away from the base. The actual cap is the red plastic bit.
    Quote Originally Posted by Alfred View Post
    Thanks
    If you haven't been to the bottom of the Brisbane river, I don't see taking that cap off making any difference. They aren't air tight any way. One trip to the shops would get the engine warm enough to evapourate any moisture.
    If it starts, just drive it.
    Dec 2013
    I've driven about 50kms this week and it isn't getting any better.
    What isn't getting any better, you haven't given us the symptoms yet?
    Dec 2013
    Good point The engine runs rough, engine shudders and misfires when accelerating at all RPMs and in all gears and the car shakes at idle. I had RACQ look at it. When he removed each of the lines running from the distributor to the cylinders two of them ran very poorly. He said it was likely moisture in the distributor/spark plug lines/spark plugs. See if it dries out but if not take it to my mechanic.
    Sterling work by the RACQ man there. So to me it sounds like maybe a couple of the plug leads are breaking down. In my experience, a prime cause of misfires has been the leads.
    However, first removing the car and cleaning it inside and out isn't a bad idea. The spring clips in your picture hold it on. Check the rotor too.
    Take the plug leads out one at a time and clean/inspect them. Then refit.
    If it still runs rough. I am not a fan of the heatshields over the plug ends of the leads. So take them off.
    Dec 2008
    Sydney/Canberra
    I'd be inclined to do the whole lot in one go.
    Distributor cap, rotor button, leads and spark plugs. The difference in performance will be night and day. The parts aren't too dear either.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Dec 2014
    Kellyville, NSW
    Pull the distributor off,no need to remove the leads, give the points a light going over with fine grit sandpaper or scotchbrite, do the same thing to the front edge of the rotor. Put the distributor back and start the car, if it runs better, job done, otherwise replace the leads too.
    Quote Originally Posted by mike90tsi View Post
    Points died a death in MK1s, this is a MK3.
