Page 39 of 47 FirstFirst ... 293738394041 ... LastLast
Results 381 to 390 of 462
Thread: Ben vs Mk3. Round 2.
  1. #381
    Sep 2006
    Parkinson / Brisbane
    wholly fark, do work son....... Well done! tank looks ace
  2. #382
    Jun 2008
    melbourne
    Gee ben you aint mucking around.
    Great to see some progress from at least one 3dr owner unlike some......
    White Scirocco R
    White MK3 Golf 2dr
    White Caddy (Work Van)
  3. #383
    Sep 2009
    Ha thanks guys, I do love getting stuck into some work. Not much done over the last couple days, uni and such takes priority (sometimes ) but I've finished up wiring the amp and relays for compressors and all that up on that panel in the spare wheel well which took a bit of time to do nice and nearly. No photos yet, will put some up when its in the car.
    Had a bit of a play with the tube bender I got, it makes really nice bends!
    Hardline teaser:
  4. #384
    Jun 2007
    Eastern Suburbs Melbourne
    hardlines - nice.
    so you're going to fully polish them, right??
    i like volkswagens
  5. #385
    May 2010
    NQ
    Haha at the size of that wire going to that relay
    MK2 - *Insert list of dealer purchased extra's/standard features here*
    80 series - The MK2's BIG, Sooty, polar opposite...
    HAHAHA
  6. #386
    Sep 2009
    Certainly will jarred
    And yeah Ryan, everything compressor related I have done in 8 gauge. Is a little overkill but not by much, they take a lot of current, besides I had a few meters just sitting around with no use
    Sent from my HTC Wildfire using Tapatalk 2
  7. #387
    Sep 2009
    Needed to clean things up a bit today, so re attached everything to the spare wheel well panel (i took it all apart to paint all the holes I drilled for wires/screws etc) and finished wiring it up.
    Bottom of it: Power and ground distribution blocks (ground one has no plastic cover on it as I lost it, I can't see this being a problem though), compressor relays and most of the power/ground wires ran to different things
    Top: Main battery fuse, fuse block for compressors and vu4, vu4, amp and a quick connect thing for the compressors. Would have been easier to put the fuses underneath and it would have tidied it up even more, but for ease of checking and such decided they should be on top.
    Ignoring the all of the other random wire and **** in general in the boot, i think it looks relatively tidy, considering how many things there are in such a small space.
  8. #388
    Sep 2009
    Have got some more work done in the last couple of days. One issue I'm really trying to address this time around is the noise from the compressors. I'm running dual Viair 400c's which are known to be some of the fastest, but also some of the loudest compressors you can get. Even mounted on a big ass piece of rubber they were annoyingly loud, the absolute worst when you're hungover I'm trying a few things to quieten them down while still keeping them on display. I could have put them under the false floor which would kill a lot of noise, but then there would be heat issues and such, and I want them to be on show
    So I've dynamatted bits in the back which I thought would resonate and also did the front doors while I was at it to improve audio quality. Obviously haven't taken the car out on the road, sounds really nice though in the car park Didn't really take photo's of this, its not that exciting, just some dynamat
    Also have put in a couple days of work into the false floor. It turned out to be a hell of a lot more complicated them I had thought to build, but its pretty much done now, just needs carpet. The black part you can see is where the compressors will be mounted, that piece is a piece of 12mm ply, covered in dynamat extreme, and then a thick piece of rubber on top of that. I'm hoping that should kill a lot of vibrations and make the compressors less noisy. There are big gaps and such in this photo too, as the floor has to be 2 parts to be able to get it in, and the parts aren't pushed together properly.
    Pretty boring update, I pretty much just post the boring things like this for my own record haha.
  9. #389
    Sep 2009
    Heaps more work done over the last couple days, doesn't look like much but getting everything perfect takes a lot of time.
    Yesterday I pretty well finished up the false floor, built a door into it for easy access to the battery and such and attached it to a latch so you just push it down to pop it open, was the cleanest way I could think of doing it. Mounted the compressors and tank and then carpeted it all too. Did a heap of measurments and some trig and made up some more hard lines and got it all connected up.
    Today I redid half the hardlines (made a rookie error of cutting them all down before tightening the fittings, so they were all a few mm too short) and polished them all up. Its all starting to look pretty good now Shalln't be posting any more photos until its all in the car which I'll hopefully do in the next few days
  10. #390
    Q
    Keep it up, impressive handy-work!
