Results 1 to 6 of 6
Thread: Testing coolant temperature gauge
    Jan 2011
    Mount Eliza, Victoria
    Hi,
    I've recently finished some major work on an ex write off VR6 and it's looking great. However, I have a small problem that is really bugging me!
    About a week ago my in-dash temperature gauge started to flicker. A couple of days ago it stopped working completely
    I'm pretty sure the cooling system run-on temperature sender unit is also the sender unit for the dash gauge, is this true?
    If so, is there a way of testing whether the temperature sender unit is broken or the gauge?
    Jul 2010
    Canberra , ACT
    you're a Legend for bringing a VR6 back from the dead ! sorry i dont know much about these technical things ..
    VW BORA 2003 V6 4Motion
    Volkswagen Golf MK3 1997 CL 1.8L
    Rammstien + Autobahn + Volkswagen = Leben !
    Aug 2007
    Yep by using a resistor wheel on the wiring, thus you become the sender, if that makes sense. you set the resistance and the gauge should respond accordingly
    JMac
    Alba European
    Adelaide hills, SA
    You can get the resistor wheel from **** Smith Electronics for less than $30.00
    Jul 2005
    Newcastle, NSW
    I funnily enough bought one from Jaycar last night for $25.
    Jan 2011
    Quote Originally Posted by Jmac View Post
    JMac
    Thanks. Do you know which of the pins to connect it to? I'm assuming it's two of the pins on the 4 pin "run-on" sender unit... is that right?
