Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Anyone running 16" rims on their MK3 golf????
    Dec 2006
    Kilsyth, VIC
    205/45R16, wheels from a New Beetle:
    No issues at all.
    Mar 2007
    QLD
    Quote Originally Posted by The_Hawk View Post
    No issues at all.
    I think these are your rims with et42 (very close to original) and I would say yours fitted without any spacers, I think my rims are going to be a problem seeing as they need spacers to clear the calipers about 5mm I think the 205/50 have to go back.
    Thanks for all your help to you and all others
    WHEEL - REGGAE 16x6.5 ALLOY
    Make : Volkswagen
    Model : New Beetle
    Model Year : 2009
    Actual items for sale may vary from the above information and image.
    Item Description
    5-Spoke Light Alloy Wheel. 16x6.5 ET42. Wheels use standard wheel bolts and rubber valve. Brilliant Silver Metallic. Additional wheel available in 15-x6-- P/N 1J9071496 666. Not compatible with TPMS
    Jan 2008
    Newcastle, NSW
    6.5 wide and ET42 is pretty muuch exactly the smae as standard (ET43), so why do you need spacers?
    Mar 2007
    QLD
    Quote Originally Posted by schoona View Post
    Hi there Mal,
    The new rims are 16x6.5, et35 without spacers the rim fouls the caliper (vr6 5 stud) - They stick out a bit from the guard with 205/50r16's -
    the whole story is I got the rims cheap and the tyres reasonbly cheap, based on what I was told from where I bought them they shouldn't of had any issues at all - but this is not the case. So I am sorta stuck with what I have now unless I can wing swapping the tyres.
    I am now wondering whether the suspension travel will even allow these tyres to contact the arches/guards, ie will bottom out before hitting - I have had some solid people bouncing on the front corner without being able to compress the springs/shockies enough (in a straight line) to contact the guard. But I have got the feeling that in hard cornering/cornering bumpy roads will be painful. The new Vr6 is in great condition, even all the plastic arch mouldings have all screws and bits, i dont wanna tear it to bits + damage the tyres.
    What rubs salt in the would is I cannot drive the car until it has rims/tyres!!!!!!!!!! I am itching to take it for a spin. will post photo of current fit
    Point Cook, Vic
    the 205/50/16 tyres are too tall moreso than too wide. Id try and exchange them for something in the correct size.
    FOLLOW US ON FACEBOOK
    Mar 2007
    QLD
    http://yfrog.com/2tp1050435rj
    http://yfrog.com/eup1050438hj
    Some photos of current new wheels fitted, what do you think. I dont think there is enough clearance
    Jan 2009
    blankedy
    Looks good, but on standard springs, think you are going to rub. Depends how much travel there is in the suspension. I'm lower than that, but my setup is FIRM.
    Erskineville, NSW
    I had a Mk3.5 Cabrio with 16x7 (no idea what the ET was) and had 205/45x16 tyres. Had no issues with rubbing or anything. Ride was good, even at 38psi.
    Mar 2007
    QLD
    Yeah, thats my thoughts too, not knowing exactly what springs are in the front, maybe if Ican tell what shockie then maybe you guys can shed some light on travel etc. Ok I have taken some photos of shockies are some sort of Koni Adjustable Sport - these were on the car when purchased, the springs appear to be proper progressive rate, ie the three bottom rings are much tighter spaced than the rest. will post a photo maybe someone can tell me more about them.
    Yfrog Image : yfrog.com/jyp1050442resizedj
