Results 1 to 9 of 9
Thread: Anyone replaced an antenna in a VR6?
    Jul 2007
    Canberra
    Hi Guys,
    In the recent rain (yes it does rain in Canberra occasionally ) it seems that I have developed a leak through the antenna. Probably going to replace it with a new one and was wondering if anyone on here has done this? Can I do it without removing the headliner? ( GOD I HOPE SO!!!)
    Simon
    Forever blowing bubbles.
    I reckon you can just remove the plastic trims around the rear hatch opening then the headlining will drop far enough to get your hand in to undo the nut on the aerial base. Getting to the cable disconnect might be a bit harder.
    Cable plug is only about 100mm from the base of the nut inside the roof.
    mk3 GTI 16v 3dr
    Jul 2007
    Canberra
    Awesome guys thanks heaps
    Vic
    x 2
    I recently did the same to replace the rubber around the base, worked well
    Dec 2006
    Kilsyth, VIC
    I did my head liner recently, so here is a photo.
    See in the back of the photo, coming from the left if the power for the booster, coming from teh right is the antenna line itself. As people have said, both can be got at after popping off the piece of trim where the hatch joins the roofy bit... this bit in fact:
    Aug 2007
    Like i have posted on MK4 forum you do not need to remove the lining to change the rubber seal. Lots of silicone and it slips over .
    Trust me
    Alba European
    Jan 2007
    Monkeyland
    I got this. Fuba antenna seal kit. Just slipped it over the top.
    http://www.parts4vws.com/catalog/pro...mber=1H0051753
    Search for fuba seal kit in google.
    Jul 2007
    Canberra
    Thanks guys, photos very helpful Hawk thanks
