Results 11 to 20 of 21
Thread: Anyone ever removed VR6 plastic wheel arch flares before?
    Jul 2007
    Canberra
    I wanted something I wouldn't have to re-apply every time I wash the car, the VHT Hood and Bumper paint seems to do the trick in that regard. You just wash it the same as the rest of the car and chamois off the water it looks good as new
    Forever blowing bubbles.
    Feb 2006
    Devonport, Tasmania
    hey guys
    i just took off my arch flares. to repaint them, or leave em off. It looks good off. but it has left me with discolour on the bodywork where the flares used to be. How do I get rid of that??? polish?? Also it also has exposed 2 holes in each gaurd where it looks like a piece of side trim continues on. Where do I get those peices???
    sorry if im hijacking
    2000 SAAB 9-5 Aero - Stage 2. 275hp 420Nm, Brew City Boost
    1986 SAAB 900 Turbo 16 S
    Jul 2007
    Canberra
    I thought about leaving mine off too but like you wasn't sure about a trim piece for those two holes. Maybe the CL or GL have those? As for the discolouration I think polish should take care of it.
    Oct 2005
    you'll have to get them from a pre-96 gl 4 dr. I did the same, but currently putting my arches back on .
    they are slightly shorter in height than the vr6 door trims but still do the trick. any one want part no.'s?
    (i will be selling the 4 pieces in the future if anyone is interested)
    as for the discolouring - just use some polish - no doubt there is a mark along the arch where it rubbed - so the polish will help get rid of this
    \'95 Golf VR6
    If you are pulling the arch covers off a 5door - this is what you need to fill the four gaps at each corner - and it never hurts to replace the eight rubber bungs either - the green thing in the middle of the pic.
    mk3 GTI 16v 3dr
    Mar 2008
    melbourne
    Smile
    Quote Originally Posted by Pullstarter View Post
    Hey Guys,
    I'm about to respray my wheel arch flares with VHT hood and bumper paint (good stuff by the way). I noticed the flares are riveted on, should i drill the rivets out and re-rivet them back in, use screws or maybe there's a better method altogether for putting them back on? Any help is hugely appreciated.
    Simon
    hey dude get those rivits in stainless steel so they don't rust and make sure that you put a plastic primer on before you paint them or they will flake off after a while sweet!!!!
    Jul 2007
    Canberra
    I used aluminium rivets, the paint I'm using has a built in plastic primer, it's especially made for use on plastics etc.
    Jan 2014
    Qld
    Quote Originally Posted by bsting View Post
    i know this is an old post hahah but where can these be found or bought?
    Mar 2012
    Central Coast, NSW
    They're just regular rear quarter and front fender trim pieces. Any non vr6 / late vr6 4 door in aus will have them. So try wreckers etc
    Q
    Wooooooooooooo, be careful with this thread man, it's an antique,
    Those end pieces are a solid solution, BUT... the early unpainted VR side mouldings are wider than those GL/CL/Vento end plugs, so although they function fine and your average person wouldn't notice/care, to get it to match spot on you'd need to replace the door strip too... which are equally as easy to find, but then you lose the VR6 badge. Another option is to get colour coded ones.
