as I said to you earlier, we had the same sort of issue when trying to place my 5x100 to 5x112 15mm adapters with 57.1 centre bore on stus vento. pulled up 5mm short of the hub. im guessing the mk3s centre bore sticks out futher then the newer 5x100 cars (mk4s and a3/tts (where your wheels came from))
Dont know if its possible to run mk4 hubs on the rear? my first suggestion would be to throw some 5mm spacers on there and see if that lets the wheel sit hard on the hub, but from memory you wanted to keep this as legal as possible?
- You may not post replies
- You may not edit your posts
Forum Rules
